1995 Ford Contour timing
120,000 MILES • 4 CYL • FWD • MANUAL
DWFWAYNE
I installed a new timing belt and pullys, but the upper cams are out of sequence where the valves do not rotate with the timing mark on the lower cam shaft pulley. Where does the back upper cam have to be set and where does the exhaust cam have to be set?
Mar 6, 2010 at 10:44 AM
  • 75,988 POSTS
See below
https://images.2carpros.com/forum/automotive_pictures/12900_cam_13.jpg
https://images.2carpros.com/forum/automotive_pictures/12900_crank_5.jpg
Mar 6, 2010 at 7:40 PM
