1995 Ford Contour Squeeling noise
1995 FORD CONTOUR
121,500 MILES • 4 CYL • FWD • MANUAL
LLARRYB
My '95 Contour makes an annoying intermitent squeeling noise. There is no real pattern to it. It never speeds up or slows down with engine speed, it will do it randomly whether at idle or cruising. It is always the same noise. I thought it was the air conditiong pump idler so I sprayed the air conditioning clutch with some WD40 and it still makes the noise. It almost reminds me of a pressure type squeal like when there is too much pressure is built up somewhere. It has been doing this for the last month. I've had the cooling system flushed and filled and diagnosed but it's alright. SO, I ani't got no idea..........
Thanks for your help!
Sep 19, 2008 at 2:51 PM
BLACKOP555
  • 10,386 POSTS
take off the drive belt, does the problem still occur?
try putting some belt dressing on the belt not wd40.
Sep 20, 2008 at 1:50 AM
LLARRYB
Ok, Thanks and I'll give it try today! : )
Sep 20, 2008 at 2:30 AM
BLACKOP555
  • 10,386 POSTS
if the coil is bad it could cause the injectors to act up and the spark.
i would try a cheap one that works and see if it remedies, its worth a try.
second you unconnected and reatached it ran good/ you remove engine running or off?
Sep 20, 2008 at 9:35 AM
BLACKOP555
  • 10,386 POSTS
i will be here waiting for your reply. i wish you luck!
