1995 Ford Contour slight grinding noise when shifting
209,000 MILES • 6 CYL • FWD • MANUAL
COPYTECH
recently had a new clutch installed, after that when shifting from 1st to 2nd and 2nd to third,or downshifting, I get a slight grinding noise from the gearbox. If this is due to a misadjusted clutch,how do you adjust the hydraulic clutch? please help,I don't want to harm the transmission! Thanks
Sep 22, 2008 at 3:58 AM
BMRFIXIT
  • 19,053 POSTS
You need to make sure clutch hydraulic system free of air
pump the clutch and bleed system
check Tranny oil
Sep 22, 2008 at 8:28 AM
