Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Contour
Ignition
Spark Plug
Replace/Remove
1995 Ford Contour oil on spark plugs
1995 FORD CONTOUR
95,000 MILES • 4 CYL • FWD • AUTOMATIC
CASPER9
MEMBER
1 POST
just changed spark plugs and found alot of oil on the spark plugs. what could cause this to happen. the car has 95,000 miles.
Feb 14, 2009 at 9:49 AM
Experienced Mechanic
Could be valves/rings and cylinder wear problems-Do a dry and wet compression test to identify where its coming from
Feb 14, 2009 at 9:58 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
