1995 Ford Contour low coolant indicator light
1995 FORD CONTOUR
50,000 MILES • 6 CYL • FWD • AUTOMATIC
LNEJMAN
Water pump replaced and coolant refilled. Now my low coolant light is on. How do I fix it
Oct 10, 2009 at 6:27 AM
OBXAUTOMEDIC
  • 3,711 POSTS
Check your Coolant Overflow Tank and make sure it is at appropriate level. If is at proper level most likely the sensor in the bottom has gone bad and to fix you will need to replace. Also check the Wiring to it to make sure it wasn't knocked off.
Oct 10, 2009 at 6:30 AM
