Hello
If I understand your problem correctly, there is a Technical Service Bulletin out on this though it specifically states 3rd it also talks about 2nd. I have attached it for your review.
Article No.
96-24-8
11/18/96
^ NOISE - "GRINDING" OR "CLASHING" HEARD WHEN SHIFTING INTO 3RD GEAR - VEHICLES WITH MTX-75 TRANSAXLE - VEHICLES BUILT THROUGH 9/1/96
^ TRANSAXLE - MTX-75 - "GRINDING" OR "CLASHING" NOISE HEARD WHEN SHIFTING INTO 3RD GEAR - VEHICLES BUILT THROUGH 9/1/96
^ TRANSAXLE - MTX-75 - HIGH EFFORT WHEN SHIFTING INTO 2ND GEAR - VEHICLES BUILT THROUGH 9/1/96
FORD:
1995-96 CONTOUR
LINCOLN-MERCURY:
1995-96 MYSTIQUE
This TSB article is being republished in its entirety to revise the service procedure and the parts required.
ISSUE:
A "grinding" or "clashing" noise may be heard from the transaxle when shifting into 3rd gear and/or a high shift effort may be required to engage cold transaxle on some vehicles. These may be due to a deflected lubrication condition causing early 3rd gear wear or high input shaft preload causing high shift effort.
ACTION:
Rebuild input shaft, changing the axial lash and installing a revised shift fork. These actions will prevent early 3rd gear wear and reduce preload to zero. Refer to the following Service Procedure for details.
Oct 28, 2008 at 11:55 AM
