1995 Ford Contour ac/heater to defrost vents only
OLDFORDGUY
Air Conditioning problem
1995 Ford Contour 4 cyl Two Wheel Drive Automatic
My brother-in-law just called with a question. He is working on 4 cyl. 95 Ford Contour. The ac/heater blower only blows out the defroster vents. He has a repair manual and is leaning toward replacement of the blend door actuator. I guess this is a dealer only part. Anyway he would like some input on what are the most likely causes of this problem?
Jul 21, 2008 at 1:15 PM
2CARPRO JACK
  • 11,533 POSTS
More likely a vacuum source problem. There is a small vacuum line that goes from the interior to the engine, ususally enters the engine comp on the pass side of the car. Be sure it is not cracked/broken, this will cause the vents to go to default (defrost) due to lack of vacuum
Jul 22, 2008 at 4:16 AM
