1995 Ford Contour No Start
TRUCK_JOCKEY
the car stalled on the road... turns over but will not start, tried a new coil pack with no change in problem, checked fuses, all ok
Jan 20, 2007 at 9:00 AM
SERVICE WRITER
  • 9,123 POSTS
Need to narrow it down to the basics-fuel, compression or spark. Do you know the status of any of them?
IF it turns overs a little quicker than normal, check the timing belt.
Jan 20, 2007 at 9:37 AM
Suggested Repair
Narrow the no-start to fuel, spark, or compression. If the engine cranks faster than normal, inspect the timing belt.
Conversation Summary
A 1995 Ford Contour 2.5 stalled and cranks but will not start. A new coil pack and fuse check did not fix it. The expert advised checking fuel, spark, and compression, and inspecting the timing belt if cranking is faster than normal.
