1994 Ford Contour light on panel blinks on and off
1994 FORD CONTOUR
137,687 MILES • 4 CYL • 2WD • MANUAL
GLYNNE04
It is the on the left side of the panel and I dont know what it means.. a yellow light = and the other night in 5th gear it just started coasting on the freeway - i had to put it in neutral turn it off and restart and it was okay - ? help
Oct 15, 2008 at 2:58 AM
BMRFIXIT
  • 19,053 POSTS
Is it the over drive light that is blinking if so I would suspect the tranny
have it scan for code
suspect internal tranny failure
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Oct 15, 2008 at 12:59 PM
