11998 Ford Contour fuel problem
PAUL WILLIAMN
The engine idles when it is in gear but will not accelerate. It just quits. Replaced fuel pump, fuel filter, oxygen sensor, throttle position sensor, mass air flow sensor and catalitic convertor and still stalls when in gear or not all I have to do is step on the aaccelerator and it stalls.
Oct 28, 2006 at 5:05 AM
NOS
  • 320 POSTS
we may have to do this one in a few steps.
1. does the car stall when it is not in gear or no load on it?
2.have you had anyone check the fuel pressure?
3.what was reason for changing fuel pump?
4is there a check engine light on? if so you need to have it scaned to find out what the codes are and thayt may give you an idea what is wrong.start whit these questions first and reply i will get message and answer back. i really need this info to give you the best answer possible.(NOS) 8)
Oct 28, 2006 at 12:18 PM
