AC Cobra Alternator Short
GOOGLER
i have an AC Cobra with a Ford 460 installed. i was hooking the electric choke to the alternator with the battery hooked up, i know, very stupid but i have done it 50 times before. i dropped the wrench and it shorted between the possitive side of the alt and the metal brake line for about 20 seconds before i could move it. there were plenty of sparks and smoke as well. now, obviosly nothing electric works at all. what steps should i take to find the problem?
May 2, 2006 at 3:31 AM
LOSONE
  • 1,616 POSTS
Hummm. The first step is to insure the battery is alive and well.
Check the red wire to the alternator. Also follow the small wire from the + post and insure it isn't burnt.
Don't forget the ground side. The current has to come back to the battery on the ground side. You might have smoked one of the ground connections either to the car, frame or from the engine to the fire wall
Your Ford has a ton of fusable links. Check them all.
Let me know
May 2, 2006 at 4:49 AM
Suggested Repair
Confirm the battery is good, then inspect the alternator red wire and the small wire from the positive post for burn damage. Check engine, frame, and firewall ground connections, and inspect all fusible links.
Conversation Summary
After a wrench shorted the alternator positive terminal to a metal brake line, all electrical systems on an AC Cobra with a Ford 460 stopped working. The expert advised verifying the battery, checking the alternator wiring for burnt conductors, inspecting ground paths back to the battery, and checking all fusible links.
