1997 Ford Cobra the radiator fan
JAKESCOBRA1997
Engine Cooling problem
1997 Ford Cobra Manual
My 1997 svt cobra's fan continues to run after the engine is off. I've checked the relays which are all fine, the thermostate appears to be working, any suggestions would be appericated, thanks
Oct 16, 2010 at 5:27 AM
BLUELIGHTNIN6
  • 16,542 POSTS
check for faulty engine coolant temp. sensor , if relays, sensor and tstat is good than most likely culprit is the PCM.
Oct 16, 2010 at 7:02 AM
