Steering feels out of Control
BRONCOBETTY
[b:38802261f2]Hi, I have a 1991 Bronco XLT, 4x4. Problem is the steering seems to overcorrect when barely turned...when let go of it is almost perfectly allligned, goes pretty straight down the road. I have 4 very good tires and balanced. It wasn't too bad before today, I just noticed when driving a normal straight road when just normal steering it would start to fishtale a little when barely moving the wheel. Then today I was turning a corner...and about a half a block later it suddenly started fishtaling like crazy and caused me to weave back and forth as if I was a drunk driver or something. And no I was sober......very scared...almost lost control.... The road was dry also and I was not going fast maybe 25-30...just starting to pick up speed after turning. It lasted about 5-7 seconds then all of a sudden steered normally again. It felt like i was on ice or something, but dry like i said. About a month ago we had a lot of snow...and I used the 4wd alot, and it made a couple of clunking sounds from the front driver side and the rear a couple of times while I was turning the wheel to back up. Don't know if it's related, but it didn't make the noise when the 4wd was off. It's a push button on the dash 4wd. Shortly after is when the whole steering thing started. Any clues or ideas would be helpful.[/b:38802261f2]
Jan 12, 2006 at 6:38 AM
BRONCOBETTY
[b:953fb3b8a6]Just bumping my own post up....after reading my post though, it sounds a little confusing.....so I could understand if no-one gets it. Hard to explain, guess ya just had to be there.
Anyway....HAPPY FRIDAY THE 13TH EVERYONE![/b:953fb3b8a6]
Jan 13, 2006 at 6:15 AM
