Can Someone tell me How can I change the Oil Pan on a 1990 Ford Bronco 302cid Without raising the engine? Can this be done?
Jan 6, 2006 at 11:01 PM
IMLIKEOJNOW
MEMBER
[quote:672c732866="the amazing raymondo"]Can Someone tell me
How can I change the Oil Pan on a 1990 Ford Bronco 302cid Without raising the engine? Can this be done?[/quote:672c732866]
You have to raise the engine the oil pan will not come out unless you do. also remove the upper intake plenum as well so you get plenty of clearance
