How can I change the Oil Pan?
1990 FORD BRONCO
THE AMAZING RAYMONDO
Can Someone tell me How can I change the Oil Pan on a 1990 Ford Bronco 302cid Without raising the engine? Can this be done?
Jan 6, 2006 at 11:01 PM
IMLIKEOJNOW
[quote:672c732866="the amazing raymondo"]Can Someone tell me
How can I change the Oil Pan on a 1990 Ford Bronco 302cid Without raising the engine? Can this be done?[/quote:672c732866]
You have to raise the engine the oil pan will not come out unless you do. also remove the upper intake plenum as well so you get plenty of clearance
Jan 7, 2006 at 12:38 AM
