NO power!!!
FORZARUSSO
87 Bronco 100k on truck, 60miles on reman motor. I just had a reman mototr put in my bronco, since i got it back it has ahd no power at all, hit the gas and pop, pop but no acceleration, took it back they told me fuel problem so i replaced both fuel pumps, EGR valve, TPS sensor, Fuel pressure regulator, fuel filter, MAP sensor, ignition swich. When you spray carb cleaner in throttlebody the truck sounds and runs great.....any help PLEEEEEEZ!!!!!
May 20, 2006 at 10:45 AM
NAI1ER
  • 15 POSTS
If it is popping you need to check the timing.
Sounds like it's advanced too far.
If it is remanufatured the timing belt may be off a tooth.
May 24, 2006 at 2:13 PM
