Ford Bronco
AARON1989
hi i have a 1989 ford bronco and i can get it to run and the timing is good and i put new plugs in it but it still dosen't want to pick up the rpms and run good it coughs and back fires and i can only get the rpms up to 4 grand and then it slowly drops down to aroudn 3 and it makes the clanking sounds liek the timing is out and it idles somtimes and somtimes it wants to but it dies and it sounds like its miss firing big time
Jan 15, 2006 at 11:00 AM
KENNJOY
  • 15 POSTS
go to the store and buy some heet and pour it into your gas tank
this will remove any water deposits you may have in your gas lines
check fuel injector or if it has a carburator check that it may need to be cleaned check fuel pump and fuel filters
Jan 15, 2006 at 4:00 PM
