Front Spndle Lock Nut
BMIKE311
I have a 88 Ford Bronco, 5.0L, 150K mi, Automatic Tranz, Manual Locking hubs (model 44).
The Front Right wheel has seized, and I am replacing the bearings. The adjusting nut will not turn. Any suggestions?
I have replaced the Left Front with no problems.
Nov 23, 2007 at 4:29 AM
MERLIN2021
  • 17,250 POSTS
Is the lock ring with the pin still in place? And you do have the right socket for these spindles?
Nov 23, 2007 at 4:35 AM
BMIKE311
Yes, I have removed the 'C' ring and pin. I also have the correct hub socket. The lock ring in the back does release when I apply pressure to the socket, but it will not turn.
Nov 23, 2007 at 4:40 AM
