ford bronco 2 wont start
BRONCOIIGUY
1990 ford bronco II, 100000, 2.9 v6. okay. i replaced the coil already so i know thats no the problem. the vehicle turns over like it always does. but the spark plugs are getting no spark. i think its the distibutor cause thats the only thing between the spark plugs and the coil. but then again maybe im wrong. is there anything else it could be cause a distributor is 100 bucks after i take the old one in.. help?
Nov 26, 2007 at 2:02 PM
BLACKOP555
  • 10,386 POSTS
check the crank sensor. also look at the distrubtor cap for cracks or carbon build up on the metal parts, also check the rotor for signs of wear. also is the coil putting out spark? try putting +12v on its +12 terminall.
Nov 26, 2007 at 11:06 PM
