deep gurgling sound when engine is turned off
MOTORMORON
my '79 Bronco with a newly rebuilt 351m, makes a very deep and noticeable gurgling sound when I shut the engine off. I've never heard this sound before, and can't pinpoint exactly where it's coming from. Any thoughts or advice?
Feb 23, 2007 at 2:14 AM
NOS
  • 320 POSTS
it sounds to me like the bearing is going out in the fanclutch. when you shut the motor off it is still turning and the bearings are gone. and it is making a grualing noise .hope this helps. 8) NOS
Feb 24, 2007 at 7:58 AM
BHUGG
  • 157 POSTS
Was the A/C running when you turned it off?
The refrigerant will continue to boil off in the evaporator until pressures in the system equalize, which can be heard in the engine compartment and inside the car. If the sound dies off after 30 seconds, and this is the sound you are hearing, then that is normal.
Try again to locate source of the noise and get back to the forum.
If our suggestions work, or even if they don't, let us know. vote for us if you think we deserve it.
Feb 25, 2007 at 2:34 AM
TAURUSWHEEL
  • 718 POSTS
Coolant full???
Feb 25, 2007 at 8:10 AM
