1996 Ford Bronco, 80000 miles, 302ci engine...
I have a check engine light that is giving me a code for "low secondary air flow", so I started checking vacuum lines and all seem intact. I traced the hose from the air pump to the black canister, and there is a dead end hose coming out of the canister, looks like it was chewed off my an animal, but I dont' see anywhere it could go to...is there supposed to be, or am I just not seeing the other end.
Thank you, Josh
Thank you, Josh
Aug 6, 2007 at 8:59 AM
