by 1989 ford bronco jumps out of 4x4
SIL438
it will jump out of 4x4 but if in low it stays in it has 164000 on it its a good running 5.0
Feb 16, 2006 at 3:10 PM
GODBEAR839
  • 77 POSTS
Automatic or manual 4x4? also do you have auto hubs or manual ones?
Feb 17, 2006 at 1:42 AM
SIL438
it goes in to like neutral and i have to hit the 4x4 buttin to get it to go back in to drive
Feb 18, 2006 at 2:06 PM
SIL438
it will work in 4x4 low
Feb 18, 2006 at 2:08 PM
GODBEAR839
  • 77 POSTS
Ok is it an automatic or a manual shifter transfer case (assuming auto since you said you hit the button) if is it auto it sounds like the motor that controls the transfer case is not stopping at the correct spot when it is shifting.
Feb 20, 2006 at 2:47 AM
