brake lights
MYFORDSUCKS
wher is the brake light fuse at and if the problem isnt the fuse then what eles could it be i have tail lights but no brake lights it on a 1988 ford bronco xlt
Jun 27, 2007 at 8:21 AM
JWALTH02
  • 180 POSTS
It's gonna be with the other fuses under the dash on the left of the driver's side. I'm not sure which number but check your manual or go through with a test light while holding down the brake pedal and see which one doesn't have power on both sides. Check those fuses.
Jun 27, 2007 at 10:30 AM
NEILCAT
it could be a blown brake light fuse. it is usually in the middle somewhere. I had this problem and eventually it became hard to get the car out of park and then it became impossible. this was because the fuse kept blowing out due to some wiring problems above my brake pedal.
Jul 3, 2007 at 1:57 PM
