1998 Ford Bronco 4x4 seems to be malfunctioning
107,000 MILES • V8 • 4WD • AUTOMATIC
MYERSJ5368
the four wheel drive works but it is rough. the weels seem like they all want to spin at a different rate. the back wheels will rotate backwards and the front wheels will jump forward while the truck is in motion. it is not at transmission problem for shure and i replaced the universal joints in both dreveshafts and it seemed to help matters but i dont know where togo from here. the last thing i want to do is replace the transfer case
Nov 18, 2009 at 11:29 AM
BIGJIM79
  • 239 POSTS
It will happen if you use 2 different size tires on the front and back. If they are the same then it would be the gear ratio in the axles.
Nov 25, 2009 at 11:41 AM
