1996 Ford Bronco Wont start
200,000 MILES • V8 • 4WD • AUTOMATIC
KAEDO
My fuel Pump is not getting power and i checked all the fuses and replaced the relay still nothing. Any suggestions? Ok I replaced the inertia switch still got nothing,and what do you mean by the computer is might not be grounding the fuel pump relay? and how would I check that?
Apr 24, 2009 at 2:50 AM
  • 75,988 POSTS
Test the fuel cut off inertia switch could also be the computer not grounding the fuel pump relay
Apr 24, 2009 at 2:54 AM
