1996 Ford Bronco vibration
1996 FORD BRONCO
235,000 MILES • V8 • 4WD • AUTOMATIC
JJSHAWNA
I had a used rear end installed in my bronco and now my bronco has extreme vibration problems, whereas it did not before. Any ideas where to start looking at?
Jun 20, 2009 at 1:16 PM
BLACKOP555
  • 10,386 POSTS
was it an exact replacement?
make sure it is properly aligned and the bearings are not damaged. try turning the wheel by hand and se if you feel any grinding or feal sticky spots when turning it or if the wheel is wobbling.
what was all replaced with the rear end. was it rebuilt?
Jun 23, 2009 at 11:15 AM
