1996 Ford Bronco valve job
1996 FORD BRONCO
125,000 MILES • V8 • 4WD • AUTOMATIC
GREGGGLASSER
The engine had an oil change just recently but there seems to be a pinging sound. my daughters froeid says it sounds like a valve. How do i know if I needa valve job and I understand that it could be the upper or lower valve. The upper is easier and the lower requires pulling the engine I hear. What is the cost and if I can't afford right now will I hurt the engine? Help
Oct 27, 2009 at 3:19 PM
  • 110,244 POSTS
THe only valves there are on the top of the cylender head. Can you describe the sound and when you hear it?
Nov 14, 2009 at 4:49 PM
