Transmission Shifting
191,750 MILES • V8 • 4WD • AUTOMATIC
JPADILLA
The overdrive "Off" light will start blinking from time to time on my Bronco. It does not happen all the time, but pretty consistently. The result is that my transmission shifts hard/abruptly. I know this can't be good for my transmission. Would the problem be in my transmission itself? Could it be a sensor somewhere?
If I stop and shut off the engine and restart it will go away. Sometimes the situation will come back and other times it will stay off. Any ideas???
Oct 29, 2009 at 1:15 AM
BIGJIM79
  • 239 POSTS
it sounds like the valve body shift motors are sticking or the valves themselves are. This sends a error code to the trans comp. and it lets you know by flashing the OD light.
Nov 25, 2009 at 11:55 AM
HOYTBROWN
What is solution to the OD light flashing and the hard shift. Module or sensor.
Feb 17, 2019 at 12:59 AM
STEVE W.
  • 15,390 POSTS
HOYTBROWN, Welcome to 2CarPros. Could you please use this link and ask this as a new question. Please give any vehicle information and any testing or parts you have tried.
Feb 17, 2019 at 9:07 PM
HOYTBROWN
The od starts blinking and rpms want to race. I can stop turn off or disconnect neg cable and restart it goes away. Is it the rear end shift sensor or something else. It has blown a fuse before for instrument panel in the past.
Feb 22, 2019 at 12:26 AM
  • 55,628 POSTS
It sounds like a pressure solenoid has gone out but to be sure lets run the codes to see what come up. here is a guide to help:
Feb 25, 2019 at 3:49 AM
