1996 Ford Bronco thermastat
EECRANK
Engine Cooling problem
1996 Ford Bronco V8 Four Wheel Drive Automatic
how to replace thermastat
Jan 23, 2010 at 12:35 PM
  • 75,988 POSTS
Sorry no diagram:
REMOVAL AND INSTALLATION
1. Disconnect battery ground cable.
2. Drain radiator.
3. Disconnect bypass hose at water pump and intake manifold, remove bypass tube, remove water outlet attaching bolts, bend upper radiator upward and remove thermostat and gasket.
4. Reverse procedure to install. Tighten attaching bolts.
Jan 23, 2010 at 12:43 PM
