1996 Ford Bronco removing oxygen sensors- HELP!
1996 FORD BRONCO
211,000 MILES • V8 • 4WD • AUTOMATIC
96BRONCO
I need to replace the front O2 sensors on my 1996 Bronco. All of my efforts have been unsuccessful in removing either sensor. First I tried PB rust penetrant and a 7/8 closed end wrench, no luck. Next, I purchased a special slotted socket, no luck. I tried an impact wrench, no luck! All of this I tried with pipes cold then I tried with them hot and re-applying the rust penetrant. The sensors wil not budge. If you have any advice on getting these boogers loose, please share your wisdom with me.
Apr 24, 2008 at 1:51 PM
MERLIN2021
  • 17,250 POSTS
You'll need a touch, get the pipe screw in area cherry red, they will come out, but may pull threads. Or you can try an air chisel heat em up and give it a quick blast in the unscrew direction, this many times will loosen so you can get em out...
Apr 24, 2008 at 1:54 PM
