1996 Ford Bronco O2 Sensor Sending Wire
1996 FORD BRONCO
150,000 MILES • V8 • 4WD • AUTOMATIC
WILL
I am installing a air/fuel ratio gauge and need to determine the correct wire to connect to the gauge. As you know there are two sensors and each has four wires. I intend to connect the gauge at the nearest harness but am open to suggestions.
Dec 6, 2009 at 11:18 AM
BIGJIM79
  • 239 POSTS
I would suggest getting the kit that will have its own sensor and wont have the problems of cutting the wires.
Dec 8, 2009 at 1:24 AM
WILL
Thanks for the input, but I already have everything installed and need to know what wire to connect the gauge. I was going to do it myself since the Trans Temp and Vac/Boost gauges were easy to connect. Interestingly, I already have O2 sensors on this vehicle, that are tied in to the onboard computer...unless there is an adaptor to add a connection to the existing system; Cutting a wire is not a problem compared to mounting a whole other O2 sensor. [quote:75aebc56e2="bigjim79"]I would suggest getting the kit that will have its own sensor and wont have the problems of cutting the wires.[/quote:75aebc56e2]
Dec 8, 2009 at 10:28 AM
BIGJIM79
  • 239 POSTS
what systems are you running? Bully dog, banks?
Dec 8, 2009 at 8:55 PM
