1996 Ford Bronco no power
200,000 MILES • V8 • 4WD • AUTOMATIC
JAVAMAMA
when accelerating it has no power at all. when in reverse it seems to have normal power. this has been a sudden problem it has been driving just fine
Jul 4, 2010 at 12:45 AM
  • 75,988 POSTS
Possibilities: Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard
Jul 4, 2010 at 3:14 AM
