1996 Ford Bronco interior electrical
126,000 MILES • V8 • 4WD • MANUAL
TITANZRM
my 96 ford bronco has electrical issues the blinkers wont work, the speedo,nor the heater and the radio also the brakes system light stays for the ubs system the flashers work fine and the rest of the gages work truck starts and runs fine. I checked all the fuses both inside and under the hood they are fine changed the flasher units both of the the one in the fornt fuse panel and the one in the back fuse panel. The manual mentions a fuseable link but I'm not sure what they look like on a ford or where they are located. I would appreiate any help you can give on this isssue thanks and have a good day.
Oct 13, 2010 at 7:46 AM
BMRFIXIT
  • 19,053 POSTS
Fusible links are located on the front of the right fender apron, at starter relay.
also suspect and check ignition switch
Oct 13, 2010 at 2:36 PM
