1996 Ford Bronco engine hesitates when restarting hot
168,000 MILES • V8 • 4WD • AUTOMATIC
AFERRERO
the truck has 168k miles and usually runs great. during the summer months, if i shut the truck down and restart it within 10-30 minutes, it has problems. the truck will start but is stumbles, hesitates, burps gags sputters and then it finally dies. I have to press the accelerator to give it some extra gas to keep it going. once it gets going, it runs like a champ. the problem started last summer along with a P071 and a P074. (system too lean banks 1 and 2) i replaced 3 O2 sensors, the MAF sensor, plugs and wires and fuel filter. the problem and the codes went away. this summer, they're back. sputtering engine and codes. not sure if they're related but i cannot figure it out. help!!![img:e8b67a33fd]http://www.2carpros.com/forum/automotive_pictures/384354_fre_1.jpg[/img:e8b67a33fd]
Jul 23, 2010 at 3:13 PM
  • 75,988 POSTS
Lean fuel condition could be caused by one of the following below:
1.Vacuum leaks
2.EGR valve/EGR DPFE sensor and PCV valve.
3.Low fuel pressure.
4.Dirty fuel injectors.
5.Mass Air Flow Sensor.
6.Oxygen sensor
Jul 23, 2010 at 9:55 PM
