1996 Ford Bronco Engin Problems
168,000 MILES • V8 • 4WD • AUTOMATIC
JODEE3675
I just purchased a 1996 Ford Bronco. The check engine light is on and I have run the codes one is saying that it is running to lean and I dont know what is causing that the next code said that it is misfiring on the #5 cylinder. I have replaced the spark plugs, wires, and distributor cap. I can't think of what else that would make it misfire on one cylinder. please help
Jan 28, 2008 at 12:28 PM
  • 75,988 POSTS
Try this check the DPFE/EGR
A misfire in a specific cylinder should lead you to check the spark plug, fuel injector and compression.
Misfires can be caused by worn or fouled spark plugs, a weak spark (weak coil, bad spark plug wire), loss of compression, vacuum leaks, anything that causes an unusually lean fuel mixture (lean misfire), an EGR valve that is stuck open, dirty fuel injectors, low fuel pressure, or even bad fuel.
A Random Misfire code P0300 usually indicates a vacuum leak or bad fuel
Jan 28, 2008 at 12:52 PM
JODEE3675
Thanks for the quick reply. I will tyr looking at these things tomorrow. I let you know how that works out.
Jan 28, 2008 at 2:25 PM
JODEE3675
Well here are the codes for sure so could you help me with these. p1351.
Jan 28, 2008 at 11:48 PM
