1996 Ford Bronco car will not start
138,000 MILES • V8 • 4WD • AUTOMATIC
CAOLIVER
It has been sitting for about 6 months. It has new gasoline in it and it will not start. The battery is good. All fuses are good. It sounds like it wants to start, but will not turn over.
Nov 22, 2009 at 9:56 AM
  • 75,988 POSTS
Do below
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Nov 22, 2009 at 10:19 AM
