1996 Ford Bronco Body Shaking at High Speeds
196,000 MILES • V8 • 4WD • AUTOMATIC
GJACKSON46
The Bronco runs fine, except that at higher speeds, the entire body starts to vibrate.
It continues even when you take your foot off the gas pedal and does not stop until the vehicle is below 50 mph.
Otherwise, there are no problems with acceleration, etc.
Also, the right side of the engine lifters are once again, EXTREMELYloud. It almost drowns out the sound of the Flowmaster muffler (smile - this is only a joke, it's not quite that bad). Do you have any recommendations that I can implement or do I need to consult a professional mechanic (again)?
Thanks!
Mar 6, 2008 at 1:28 AM
2CARPRO JACK
  • 11,533 POSTS
If it isnt oiling one side of the engine, It needs some serious work. The vibration. have you had the wheels balanced? Any front end work done? at that mileage it should have had a complete front end rebuild
Mar 6, 2008 at 4:40 AM
