1996 Ford Bronco
1996 FORD BRONCO
85,000 MILES • V8 • 4WD • AUTOMATIC
KIKI45
I live in Ca. where you need a smog inspection. The truck passes all emissions but due to battery changing the computer needs to be reset to give an accurate reading to pass. How do I reset
Nov 13, 2008 at 3:06 AM
  • 110,244 POSTS
Is there a problem with the alt causing the light to be on? You may want to have a nationally recognized parts store reset the light for you. There shouldn't ba a charge, and you may need special tools to do so.
Nov 25, 2008 at 3:16 PM
