1996 Ford Bronco
192,471 MILES • V8 • 4WD • AUTOMATIC
AHONDAEATER
My 1996 ford bronco fill size has had a problem that I am trying to pin down I just keep replaceing parts runs for awhile and than stalls. I had a code P0320 I replaced the coil, cap, rotor, wires, plugs, tfi, and crankshaft sensor still same problem. runs good when it runs Iam getting frustrated. Just today it ran for about 1 minute and acted as if you shut the key off (died) wont start. Can you help?
May 26, 2008 at 3:10 PM
BMRFIXIT
  • 19,053 POSTS
check what missing fuel or spark
check and or replace EEC power relay
May 26, 2008 at 11:51 PM
