1995 Ford Bronco water intake
1995 FORD BRONCO
150,000 MILES • V8 • 4WD • AUTOMATIC
BRAD1969
i went off roading went through puddle water came over hood drove right out engine stalled. Started back up sounded bad. towed home changed plugs and oil. Also distributor cap turns over but wont fire up. Battery is weak have tried jump starting with smaller battery. what else might be wrong?
Mar 13, 2008 at 8:59 PM
BMRFIXIT
  • 19,053 POSTS
check wires and coil
make sure you have the correct firing order
charge battery
week battery will cause flooding
Mar 13, 2008 at 9:17 PM
