1995 Ford Bronco V8 351W, EFI
BRIAN1
There is a ticking noise coming from the area of the injectors. When I place my hand on the fuel tree I can feel a vibration that coincides with the ticking noise. I don't know if the injectors need to be replaced or it is something else. Any help would be greatly appreciated.
Mar 5, 2007 at 7:49 AM
MERLIN2021
  • 17,250 POSTS
is the ticking overly load? some ticking in the early sefi models is normal.
Mar 5, 2007 at 9:57 AM
BRIAN1
[quote:503a6c77d5="merlin2021"]is the ticking overly load? some ticking in the early sefi models is normal.[/quote:503a6c77d5]
It is pretty loud even when the hood is down. Running a little rough at idle, but running great any other time. Brian
Mar 5, 2007 at 9:54 PM
  • 75,988 POSTS
[quote:3533063ea8="Brian1"]There is a ticking noise coming from the area of the injectors. When I place my hand on the fuel tree I can feel a vibration that coincides with the ticking noise. I don't know if the injectors need to be replaced or it is something else. Any help would be greatly appreciated.[/quote:3533063ea8]
All the clicks should sound the same -if you find one that's sounds different than the rest-check it.
Mar 6, 2007 at 6:23 PM
