1995 Ford Bronco steering
118,000 MILES • V8 • 4WD • AUTOMATIC
TUFF
What would increase the stability of my steering? My truck has 6 inches of lift running on 35 12.50s, when I'm driving the slightest change in the road surface causes my steering to vere and sometimes jerk in one way or the other,would steering stabilizing shocks correct this problem?
Dec 3, 2007 at 3:59 AM
MGERSH7
  • 6 POSTS
IF YOU ARE RUNNING 35 GET A DUAL STABILIZER KIT WILL HELP. CHECK ALL YOUR FRONT END PARTS AND CHECK FREE PLAY IN STEERING BOX ALSO. CHECK SWAY BAR LINKS ALSO. POSSIBLY FRONT END PLAY SOMEWHERE. GOOD LUCK
Dec 12, 2007 at 5:56 AM
