1995 Ford Bronco running rough
123,000 MILES • V8 • 4WD • AUTOMATIC
ALLSTAR802003
I have a 1995 ford bronco with a 5.8 efi 351 windsor and I have been having this problem for a few days now. When its in park it idles, runs, and sounds good, but when i put it in drive and take off down the road it starts to run rough and acts like its starving for fuel. I've changed the throttle position sensor, map sensor, fuel filter, and air filter. I've cleaned the throttle body, injectors, and gas line. I've checked the spark plugs and spark plug wires, the catalytic converter, and fuel pressure, and all of those are working good. I don't know what else to do or to check. Can you help me and give me an idea of what may be the problem, or what i can do?
May 30, 2010 at 4:21 AM
  • 75,988 POSTS
Inspect and test all the following listed below
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
May 30, 2010 at 8:37 AM
