1995 Ford Bronco Putting in Drive
187,000 MILES • V8 • 4WD • AUTOMATIC
RIQUE74
I cant seem to get truck in drive unless I shut truck off and when going to restart I can put in neutral and then start it and it runs fine once started. Can faulty brakes be the issue or ignition. Thanks for the help
Apr 17, 2010 at 11:37 AM
  • 110,246 POSTS
Is the problem the shifter doesn't shift or it does and won't go into gear?
Apr 20, 2010 at 3:12 AM
