1995 Ford Bronco Oil pressure...
1995 FORD BRONCO
189,000 MILES • V8 • 4WD • AUTOMATIC
BIGEASY
Just picked this bronco up. Oil pressure gauge isn't moving. Then check engine light came on. Checked oil level, o.k. Assuming oil pump or pick-up line. How can I inexpensively check oil pressure / diagnose issue? Do the electronic hand held diagnostic testers only work from 1996 and later? Thank you.
Oct 24, 2008 at 2:08 AM
DOCFIXIT
  • 18,828 POSTS
Hook up a mechanical gague to where oil sender is .and see if it just gague problem or pump.
Oct 25, 2008 at 4:57 AM
