1995 Ford Bronco Oil Pressuer
155,594 MILES • V8 • 2WD • AUTOMATIC
CONROY33033
My 1995 Ford Bronco 5.0 V8 will occasionally lose oil pressure according to the gauge when accelerating rapidly, but the gauge will then say that my oil pressure is normal five minutes later or if i shut the engine off and then restart it, what could be the reason for this?
Aug 3, 2008 at 1:48 AM
MERLIN2021
  • 17,250 POSTS
You can remove the sender, install a test gauge, and take some readings, If they are normal, replace the sending unit. 5-10psi warm idle and increase to 40-60 as you rev it up.
Aug 3, 2008 at 1:56 AM
