Engine Performance problem
1995 Ford Bronco V8 Four Wheel Drive Automatic 185.32 miles
when starting engine , it will idle up to 2000 rpm with the engine light coming on itermittently, it takes more than the normal time to idle down and does not do this all the time & will not respond to pedal kickdown...temperature change has not made a differance here in north texas.
Sep 8, 2008 at 6:57 AM
