1995 Ford Bronco help me please help me please
150,000 MILES • V8 • 4WD • AUTOMATIC
ARTHURL475
I went to the gas station and filled up my bronco and during the same time the gas station was filling up so now when i drive my bronco and get up to about 50 mph it starts to shake and jerk real bad.. so i replaced the plugs, wires, cap and rotor new fuel filter and i even seafoamed the dam thing and it still does the same thing so now im leaning towards the fuel pump so help me please help me please
Feb 26, 2010 at 1:57 PM
BLACKOP555
  • 10,386 POSTS
drain out all the gas and put fresh gas in the tank and change the filter again. then try to run it. does it run now?
what to do with that other gas.... use it in the lawnmower or mix it in your tank with fresh gas until you run it out
Feb 27, 2010 at 1:21 AM
