1995 Ford Bronco fuel pump noise/performance
180,000 MILES • V8 • 4WD • AUTOMATIC
DAVID POPE
I'm seriously considering buying a 95 Bronco,5.8 liter with 180000 miles.My question is;Should the fuel pump run constantly?{It does}And,shoud I be able to hear it?{I can.}The present owner says the pump has recently been replaced.Thanks so much.You guys are great!
Nov 12, 2008 at 1:58 AM
  • 110,246 POSTS
Hi:
The fuel pump can be heard but shouldn't be too loud. As far as running all of the time, it should shut down when pressure is reached. Does the pump run all of the time w/out the engine running?
Nov 25, 2008 at 3:19 PM
