1995 Ford Bronco Front Driveshaft
118,000 MILES • V8 • 4WD • AUTOMATIC
TUFF
I was wondering if four wheel drives equipped with full time hubs should the front driveshaft spin freely when the push button 4x4 is not engaged and it is not running?
Dec 3, 2007 at 3:50 AM
JWALTH02
  • 180 POSTS
Yes if it is not engaged the front drive-shaft should spin freely. But if you have the "automatic" hubs, they sometimes like to engage and then not disengage. I have a 92 that had them and immediately switched them with some Warn Manual hubs and haven't had a problem.
Good luck let us know if you need anything else!
Dec 6, 2007 at 3:27 PM
